SAAB 9000 CSE CLUTCH
Komax67
- Registrert: 04 aug 2013, 15:41
- Medlemsnummer: N2625
- Bil: SAAB 9-5 1,9 TiD Vector
Hei, ifb et realt clutch-havari, ser jeg at dety er to forskjellige typer clutcher, avhengig av motornr. Hvor finner jeg dette nummeret? Har motorkoden, det er en B204E, men finner ikke motornummeret som skal begynne på V0 osv..Noen som har et tips???
- odin1899
- Registrert: 06 jan 2013, 19:46
- Bil: 9000 CSE '97 2.3T Anni LPG
Re: SAAB 9000 CSE CLUTCH
Ifølge Haynes (p.0.10) :
The Vehicle Identification Number (VIN) plate is located on the right-hand side of the bulkhead in the engine compartment (see llustration). It is also stamped in the body, to he left of the right-hand rear light. On pre- 1989 models, it is on the crosspanel to the ear of the luggage compartment: on 1989-on models, it is on the crossmember inside the spare wheel well. On 1994-on models, it is etched into the windscreen and rear window.
The engine number is situated on the lefthand rear face of the cylinder block on 2.0 litre models up to 1993, or on the left-hand front face of the cylinder block on 1994-on 2.0 litre and all 2.3 litre models.
The transmission number is situated on the top of the transmission casing. The body trim and colour code is stamped on a plate located on the right-hand side of the bulkhead in the engine compartment on 1985 models, on the panel at the rear of the luggage area on models up to 1990, and on the left-hand rear door pillar on models from 1991 onwards.
Saab 9000 CSE Anni '97 2,3T
Det finnes 228mm og 240mm clutch, nå skriver du ikke årsmodell, men til en B204E som er på 150 hk så skal det være 228mm. Motornummer på en gammel rusten blokk kan du nok bare gi opp å tyde.
Komax67
Det er en 1996 mod. Iflg Speedparts så er alternativene en på 215 mm og en på 240 mm..
