Justering av giroverføring
- Registrert: 21 jul 2014, 21:36
- Medlemsnummer: N806
- Navn: Gunnar Nedgården
- Bil: Saab 9-5 2001 mod
Hallo . Har bytta clutch på Saab 9-5 01 mod til Aero clutch , men etter bytte er den litt vond å få i andre gir , alle andre er bra .Den var bra før det ble bytta.Kan dette være at overføringen ikke er blitt monter nøyaktig etter bytte ? Håper noen har vært borti dette før . Mvh Gunnar
- TurboTrykk
- Medlemsnummer: N2716
- Navn: Chris
Re: Justering av giroverføring
According to the Haynes manual, there is an alignment hole (covered by a plug) at the top of the gearbox housing. Remove the plug and with gear in 4th you should be able to insert a screwdriver with a 4mm dia shaft (only use a screwdriver so as not to lose it into the gearbox), locking the gearbox in 4th gear. Now remove the gear lever gaiter and mounting frame and at the front of the gear lever housing there should be another alignment hole into which you should be able to insert a 4mm dia screwdriver or drillbit. If you can't then the gear linkage isn't aligned as it should be. To adjust this slacken the pinch-bolt where the gear selector rod passes through the bulkhead (near the rubber coupling). Move the gear lever so the screwdriver or drillbit can be inserted into the hole (with gear lever in 4th). Tighten the pinch-bolt in the engine bay and then remove all drillbits and screwdrivers (or whatever you used) and replace everything else. Test to make sure you can engage all gears smoothly and that you can remove the key with gear in reverse. Test drive. That should be it.
9000 2.3t CSE 1995 - Skrotet
Re: Justering av giroverføring. Løst
Da ble det i orden etter ny justering . Takk for hjelpen .
