Feilkoder.
stålehansen
Registrert: 02 sep 2009, 20:39
Navn: Ståle Hansen
Bil: MY98 9-5 2.0t Steg 1R
Feilkoder.
Legg inn av stålehansen » 14 sep 2016, 17:00
Hei noen som vet hva feilkode p0108 er og p1108. Saab 9-5 98 mod.
redturbo
Navn: Tom Hummel
Re: Feilkoder.
Legg inn av redturbo » 14 sep 2016, 19:00
Generell og merkespesifikk :
http://obdii.pro/en/code/P0108
http://obdii.pro/en/code/P1108
Svensk/engelsk, velg øverst til høyre:
http://saabinfo.se/og-9-5/error-codes/o ... s/?lang=en
Det lønner seg å beskrive hva feilen består i og hva du har undersøkt hittil. Generelt så undersøk nøye ledningsbrudd eller jordfeil til alle følere som gir input i den aktuelle feilen.
redturbo
Navn: Tom Hummel
Re: Feilkoder.
Legg inn av redturbo » 14 sep 2016, 19:38
p0108: Fant dette som ikke var er åpent tilgjengelig (pga feil?) om det kan hjelpe deg:
The temp sensor and the charge air sensor are one in the same.
its a 4 wire sensor with 2 wires for each sensor they are both built into each other.
Charge air absolute pressure sensor
The pressure sensor contains two metal coated ceramic discs mounted close to each other. The disc closest to the pressure connection is thinner and bends when exerted to pressure. This bending will change the capacitance between the metal coating on the two discs depending on the pressure. Integrated in the sensor is a circuit that converts the capacitance to analogue voltage. The pressure sensor, which is combined with the temperature sensor, is located on the engine intake manifold and is supplied with 5V from control module pin 46 and grounded from control module pin 70.
Depending on the pressure in the charge air pipe, the pressure sensor delivers a proportional voltage to control module pin 35.
The air mass control determines which air mass/combustion is to be drawn in during the cylinder's induction stroke. The value corresponds to the engine torque.
Throttle control adjusts the throttle so that the current air mass/combustion is the same as the requested.
If the air in front of the throttle has a high density, a smaller throttle angle will be required than if the air density is low. The density of the air is therefore calculated by the control module using the charge air pressure and the intake air temperature.
When checking the pressure sensor with a pressure/vacuum pump, slightly lower voltages may be obtained at high altitudes.
Diagnostics
•If the sensor voltage is too low, diagnostic trouble code P1107 will be generated.
•If the sensor voltage is too high, diagnostic trouble code P1108 will be generated.
•If the pressure value is implausible, diagnostic trouble code P1106 will be generated.
•If the hose to the sensor breaks, diagnostic trouble code P1105 will be generated.
At normal atmospheric pressure, 100 kPa, the pressure from the sensor is approx. 2.1 V.
Voltage at
25 kPa (-0.75 bar)
V approx. 0.9
50 kPa (-0.50 bar)
V approx. 1.3
100 kPa (±0 bar)
V approx. 2.1
125 kPa (0.25 bar)
V approx. 2.5
150 kPa (0.50 bar)
V approx. 2.9
175 kPa (0.75 bar)
V approx. 3.3
Pressure given in kPa refers to absolute pressure, i.e. 100 kPa corresponds to barometric pressure at sea level.
stålehansen
Navn: Ståle Hansen
Re: Feilkoder.
Legg inn av stålehansen » 15 sep 2016, 03:27
Se der ja. Tusen takk.
