http://www.mtsautopart.no/_shop/product ... s_id=11764
HKS Type-1 New Turbo Timer. HKS's new turbo timer for 2008 is the ninth generation turbo timer, now available! The Type-1 features standard turbo timer functions along with a blue backlit display, auto timing mode, vehicle speed and rpm display, and a two-stage RPM shift warning light.
HKS Type-1 turbo timer also features the 1/4 mile timer, 0-60, and a stopwatch function that can be used for lap timing. Display units can be changed from MPH or KPH.
Positive Lit LCD
Blue Back Light
Black Display Case (W:89.5mm/H:22.5mm/D:13mm)
LCD Display (W:41.5mm/H:11mm)
Black Control Unit Case (W:69.0mm/H:80.0mm/D:21.0mm)
Timer Functions:
Manual Mode (0-10 Minutes)
Memory Mode #1 (1 touch, 1 Minute Setting)
Memory Mode #2 (1 touch, 3 Minute Setting)
Auto Mode (0-5 Minute Setting)
Battery Voltage Display:
Battery Voltage
Peak Value Indication
ON/OFF Warning Function
Vehicle Speed Indication Function:
Vehicle Speed
Peak Speed Hold Value
Speed Warning Function
Engine RPM Indication Function:
Engine RPM
Peak Engine RPM Hold Value
Engine RPM Warning Function
Display in either MPH/SAE or KPH/Metric
Metric Distance Time Functions:
Acceleration Distance (0-100m, 0-200m, 0-400m)
Section Time (200-400m)
Acceleration Time (0-100km/h, 100-150km/h)
Auto or Manual Start for Quarter Mile Function
SAE Distance Time Functions:
Acceleration Distance (0-60 foot, 0-1/8 mile, 0-1/4 mile)
Stopwatch Tool Time Measurement
Total Elapsed Time
Lap Times
Compatible with all HKS Turbo Timer Harnesses
