Speedparts Norway forhandler nå følgende oljer
EMPEROL RACING 10W60, denne kan du kjøpe i 1 liters flasker hos oss ! Prisen kr 199.- pr liter
Description
A full-synthetic motor oil formulation, produced with high quality synthetic base oils and a well balanced choice of advanced additives to obtain the following properties:
Excellent shear stability
High and very stable viscosity index
Fast cold start
Safe lubrication film at very high temperatures
Very good detergency and dispersion properties
Very strong protection against wear, corrosion and foaming
Application
A full-synthetic motor oil, recommended for use in powerfull petrol and diesel engines, with or without turbo charging. Due to excellent lubrication properties at all times and a very good resistance against oxydation this motor oil is also suitable for use in rally and car racing.
Typical standard analyses
Density at 15 °C, kg/l 0,853
Viscosity -25 °C, mPa.s 3600
Viscosity -20 °C, mPa.s 1800
Viscosity 40 °C, mm²/s 142,20
Viscosity 100 °C, mm²/s 23,00
Viscosity Index 192
Flash Point COC, °C 224
Pour Point, °C -40
Total Base Number, mgKOH/g 9,7
Sulphate Ash, % 1,22
