Norwegian language is prohibited (or should be used VERY sparsely) in this forum, as the intent with it is to discuss with Saab-enthusiasts from countries without trolls and telemarkski. Feel free to discuss all kind of Saab-related topics, but don't make threads dedicated to own projects (links to other forums are welcome).
Shauns
- Registrert: 06 apr 2011, 17:25
av Shauns » 06 apr 2011, 19:29
hei hello
can anyone of you well versed saab fans let me know what turbo trykk i should have on my 2003 model saab 9-3 turbo 2,0l vector
and how much i can boost to before it becomes detrimental to the enginie maybe up to 1,2 bar??
many thanks in advance
and sorry if this question has been asked before,but for some reason im not able to get into the member area.
thanks again
Shauns
av Ingvar N629 » 07 apr 2011, 13:21
Hi, and welcome to our forum!
Tuning questions should be posted in the tuning part of the forum; "Trimming". If you become a member, you'll be given access to it.
Your engine management system doesn't aim for a fixed boost pressure as boost is not a fixed parameter in the software. The Trionic 8 engine management system is quite sophisticated and determines the engine torque by airmass/combustion. The boost can therefore vary a bit depending on ambient conditions, as the Trionic 8 system aim for the same torque regardless of ambient conditions (within limits) to achieve the desired performance.
You can NOT manually increase the boost, this MUST be done through software modification. Attempts to trick the Trionic 8 system will result in a harsh running engine without increased performance, or in worst case engine failure.
Shauns
av Shauns » 07 apr 2011, 14:16
i am a member
but for some reason it wont let me into the members area
medl.nr N2031
mvh
Shauns
av Ingvar N629 » 07 apr 2011, 16:22
In that case, PM one of the admins Hjelle N6 and Daniel N683, and they'll open up for you
